06-24-2005 11:18 AM - edited 03-15-2019 03:32 AM
i have a voice gateway which has been configured to set up calls frm PSTN to a CCM using H.323 signalling.How do i configure the CCM so that the phones recieve inbound calls
06-24-2005 02:15 PM
You will have to setup VoIP dial-peers on the h323 gateway pointing to the IP address of CCM:
06-25-2005 06:14 AM
The voice gateway has already been configured with voip dial peers pointing to the CCM
06-24-2005 02:19 PM
Hi, you have to add the H.323 GW in the CCM for Devices options>Gateways and then select H.323 GW. To receive calls from the GW you have to put the options for CSS in the GW config (there is an option for incoming calls) allowing those calls to the IP phones.
Daniel.
06-26-2005 12:20 AM
Thanks for your response..Where exactly do u specify the ip address of the gateway .
