Configuring IVR on ISR 2801 with CCME 3.3
Hello all!!!
I try to configure b-acd service on 2801 with CCME. All works fine, but I suspect that when customer dial pilot number, and do not press any key, the line stay active until Customer on-line (he listen repeating en_bacd_options_menu.au :) )
so the is frizen :(
How can I configure, to automaticaly transfer this call to operator or drop
call?
6 Replies 6
l.colmenares
Hello!
I´m trying to configure B-ACD on callmanager express 4.0 and i dont know what happens but i don´t listen the .au messages...
this is my configuration:
application
service queue flash:app-b-acd-2.1.0.0.tcl
param queue-len 10
param aa-hunt1 200
param queue-manager-debugs 1
param number-of-hunt-grps 2
param aa-hunt2 201
service acctfixedpin tftp://10.2.2.1/acctfixedpin.tcl
param uid-len 5
service aa flash:app-b-acd-aa-2.1.0.0.tcl
paramspace english index 1
param dial-by-extension-option 5
param handoff-string aa
paramspace english language en
param max-time-vm-retry 2
param aa-pilot 2395520
paramspace english location flash:
param second-greeting-time 60
param call-retry-timer 15
param max-time-call-retry 600
param service-name queue
dial-peer voice 500 pots
service aa
incoming called-number 2395520
port 0/0/0
dial-peer voice 1004 voip
service aa
destination-pattern 2395520
session target ipv4:192.168.1.2
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
telephony-service
load 7960-7940 P0030702T023
load ATA ATA030100SCCP040211A
load 7902 CP7902080001SCCP051117A
load 7912 CP7912080001SCCP051117A
max-ephones 24
max-dn 72
ip source-address 192.168.1.2 port 2000
system message Imagen Proactiva
time-zone 14
date-format dd-mm-yy
max-conferences 8 gain -6
call-forward pattern .T
moh music-on-hold.au
web admin system name cisco password cisco
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp 7960 Apr 04 2006 16:14:51
ephone-hunt 1 longest-idle
pilot 200
list 100, 103, 104, 105, 106, 107, 108
timeout 10, 10, 10, 10, 10, 10, 10
ephone-hunt 2 longest-idle
pilot 201
list 101, 102
timeout 10, 10
Am I missing something????
May be:
param welcome-prompt _bacd_welcome.au
or if you use your audio files, they may in in incompatable coding ...
skhilnan
Best way to do this is to use Cisco Unity Express and the AA capability on it. Much more flexible and powerful, and more easily managed.
Sarat
Can you get additional information? May be link to CUE. How I can install and configure this feature on Cisco 2801 ISR?
Sorry, but does ISR2801 support CUE modules?
