CUBE routing via Called Number and ANI
joshbradley604
Basically what were trying to achieve is the following:
1) People call 111-222-3333
2) People with a Calling Party number beginning with 403....... and 613....... we want to route to a different destination and strip the 111-222-3333 and turn it into 111-222-4444
Has anyone ever done this?
Can it be done?
6 Replies 6
R0g22
You can use E.164 pattern map to match the dial-peer based on calling number and have dpg on this incoming dial-peer to match a specific outgoing dial-peer which would have a translation to translate the called number as you please.
I should have mentioned that the call flow is:
PSTN > ITSP > CUBE > Contact Centre platform
So what you suggested should still work?
It should. Configuration is local to CUBE irrespective of the call flow.
I’d need to see a sample config based on my input above to really grasp how this would work.
If you don’t have time it’s all good and I appreciate you responding to my post.
Right now on the Inbound leg from ITSP we are matching by URI.
Im not sure if I can make another Dial Peer to match by URI and pattern map.
If you already have matching by URI, then that takes precedence. You can share your config, I will check on it. A sample config for the solution that I highlighted above is the following -
voice class dpg 1110
dial-peer voice 1110
voice class e164-pattern-map 1112
e164 403.......
e164 613.......
dial-peer voice 1112 voip
incoming calling e164-pattern-map 1112
destination-pattern dpg 1110
dial-peer voice 1110 voip
destination-pattern XXXX
translation-profile outbound MODIFY
I am assuming you can add the translations on your own.
