CUBE - Smart License - Token expired
CoDeC
we have a couple CUBEs (ISR4431 - IOS XE17.03.04a)  where "Cisco Software Central > Smart Software Licensing" show that they have their tokens expired.
CUBEs are working with usual. following you can see the output of the command "show license status" and "show voice sip license status"
cube01#sh license status
……………… output cut ………………………
Usage Reporting:
  Last ACK received: Jan 12 07:05:42 2023 CET
  Next ACK deadline: Apr 12 07:05:42 2023 CET
  Reporting push interval: 30  days
  Next ACK push check: Jan 12 18:46:21 2023 CET
  Next report push: Feb 11 18:01:02 2023 CET
  Last report push: Jan 12 18:01:02 2023 CET
  Last report file write: <none>
Trust Code Installed: Sep 15 21:13:41 2022 CET
cube01#show voice sip license status
Host Name: cube01
Current Time: Jan 12 2023 18:48:23 CET
SIP service: Up
License use recorded every: 7 Day(s)
Next record at: Jan 19 2023 18:00:01 CET
Recent use of license(s) for entitlement tag CUBE_T_STD
Timestamp                   Count
Jan 12 2023 18:00:01 CET    48
Jan 12 2023 15:00:01 CET    67
Jan 12 2023 14:00:01 CET    41
Jan 12 2023 11:00:01 CET    71
Jan 12 2023 10:00:01 CET    46
Jan 12 2023 09:00:01 CET    15
Jan 12 2023 07:00:01 CET    1
Jan 12 2023 06:00:01 CET    2
Jan 12 2023 04:00:01 CET    1
Jan 12 2023 03:00:01 CET    2
cube02#sh license status
Usage Reporting:
  Last ACK received: Jan 11 21:05:36 2023 CET
  Next ACK deadline: Apr 12 09:00:03 2023 CET
  Next ACK push check: Jan 12 18:47:45 2023 CET
  Next report push: Feb 11 18:00:47 2023 CET
  Last report push: Jan 12 18:00:47 2023 CET
Trust Code Installed: Sep 17 21:46:12 2022 CET
cube02#show voice sip license status
Host Name: cube02
Current Time: Jan 12 2023 18:48:49 CET
SIP service: Up
Next record at: Jan 19 2023 18:00:02 CET
Timestamp                   Count
Jan 12 2023 18:00:02 CET    9
Jan 12 2023 16:00:02 CET    14
Jan 12 2023 14:00:02 CET    8
Jan 12 2023 13:00:02 CET    13
Jan 12 2023 11:00:02 CET    10
Jan 12 2023 10:00:02 CET    5
Jan 12 2023 09:00:02 CET    1
Jan 11 2023 21:00:02 CET    0
Jan 11 2023 20:00:02 CET    1
Jan 11 2023 19:00:02 CET    3
what impact in ISR4000 routers is have a token expired? thanks.
regards,
b.winter
No impact.
The duration in the portal only shows, how long a token can be used to authenticate a new device or re-authenticate an already existing device. You can also use the token multiple times for different products (like one token for CUBE, CUCM, CUC, ...). Therefore, the token has no fixed binding to only one specific device.
If you would now want to add a new device to smart licensing, you would need to generate a new token.
b.winter
No impact.
