CUE v1.1.2 not accepting calls
jeff.bankston
Platform: 2611XM 12.3(8)T5 IP-Voice code with CUE v1.1.2 NM.
My issue is that incoming calls ring properly, and after 4 rings attempt to go to the CUE, but the call gets dropped as soon as CUE picks it up. This is a new CUE install, by the way. CUE debugs and traces show proper arrival of the call into the VM pilot point, and the problem occurs on all mailboxes.
Either I have a SIP problem, or I somehow misconfigured both mailboxes.
Also, on a 7960 phone, I have only one line defined. If I press the messages button on the phone, I properly go to CUE. But, I get a message that for security reasons the attempt to reach VM must be done from the primary phone number.
I've been chasing this for close to 2 days and have found every pdf on CUE that I could find. Debugs show correct processing of the incoming call.
Any ideas?
Thanks, Jeff
noelmoore
Hi Jeff,
I'm new to this VOIP stuff for CUE and CME so I might be talking nonsense.
I've been setting this up for the first time this week and I hit the error "for security reasons the attempt to reach VM must be done from the primary phone number" ... when I manually assigned a pin code and password to that persons mailbox it sorted it.
Not sure if that's any use ;-)
Rgrds
Noel
noelmoore
Hi Jeff,
Rgrds
Noel
I can't believe that fix was that simple...... I had previously even tried setting that mailbox to a blank password, and it even accepted it.
Thanks for that little tip, and as a side note I didn't have this problem in CUE v1.1.1
Now for the last nightmare...
-Jeff
