DHCP for IP Phones and PCs
startryst
IP Phones: 10.0.0.0/24
PCs: 192.168.1.0/24
How to implement DHCP for this scenario?
IP Phones and PCs should obtain their ip address from DHCP server.
Topology:
PC<---->IP Phone<--(dot1q)-->Catalyst 3524 PWR<---->Cisco 2811 Router
I prefer to use 2811 act as the DHCP server
thisisshanky
Level 11
Level 11
Create two vlans, one for PC, one for phones.
On the switch ports conected to phones, configure this.
int fa0/1
switchport mode trunk
switchport trunk encap dot1q
switchport trunk native vlan 2
switchport voice vlan 3
On the port that connects between 2811 and 3524
int fa0/24
switchport trunk allowed vlan 2,3
On the router side
int fa0/1
no ip add
int fa0/1.10
ip add x,x,x,1 Mask
encapsulation dot1q 2 native
int fa0/1.20
ip add y.y.y.1 Mask
encapsulation dot1q 3
ip dhcp pool PC
network x.x.x.0/24
default-router x.x.x.1
lease 3
dns <>
ip dhcp pool Phone
network y.y.y.0/24
default-router y.y.y.1
lease 3
option 150 ip
dns <>
Hope that helps!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Thanks, I knew the method of using subinterface on 2811 before.
I just want to know is there other method to accomplish this?
You could have a router with two interfaces, or if you had a layer 3 routing capable switch (which the 3524 isn't) then you could set up VLAN interfaces on that...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
The switch is Catalyst 3550-24-PWR which is layer 3 routing capable switch
