Dial-peer problem
carlosjlopez
Hello all,
There?s my scenario:
Router A conected to a PBXA(dns 4XXX).
Router B conected to a PBXB(dns 6XXX).
Router A conf:
dial-peer voice 6 voip
destination-pattern 6...
session target ipv4:10.1.1.1
req-qos guaranteed-delay
ip precedence 5
dial-peer voice 1 pots
destination-pattern 4...
direct-inward-dial
port 2/0:15
prefix 4
Router B conf:
dial-peer voice 1 voip
description Llamadas Central Madrid
session target ipv4:10.1.1.2
req-qos guaranteed-delay audio
ip qos dscp cs5 media
dial-peer voice 6 pots
description Corporativos
direct-inward-dial
port 0/0/0:15
When I make a call from the PBx A with number 4000 to a 6xxx number I have a 12 seconds delay before the call run, I tested to make the call without the dialpeer 1 in router B and the call progress without delay.
any ideas??
Hi Carlos,
What's happening is the calling number (4149) is being matched to dial-peer 1. You'll see there's a 10 second delay between 11:26:29 and 11:26:39 just after it matches to dial-peer=1. When you remove the dial-peer it works OK because there's NO_MATCH.
On the one I've just implemented I had the PBX guys prefix 3 digit "steering" codes that get stripped off by the destination PBX, so I don't have this problem.
For example PBX A prepends 867 to the number dialled, which is sent to Router B. Because PBX B prepends 897 to it's dialled numbers, there's not a match.
Here's an extract from my config...
description Mt Albert Extensions
destination-pattern 8679....
session target ipv4:10.16.255.252
dial-peer voice 1001 pots
description From Mt Albert
destination-pattern 8976T
port 0/0/0:0
In my case I had the PBX add and remove the 3 digit steering prefixes but you could simply add a translation-rule to your dial-peers so that router A adds a prefix, then router B strips it before sending to PBX B.
I hope my explaination's understandable
15 Replies 15
jasiditel
Hello Carlos
Have some questions:
Are those the only two dial-peers on your system?
Are the calls on the other way working fine? (6000 calling to 4xxx)
Can you place a call 4000 to 6xxx and do a show call active voice brief
You will find there both legs of the call and you'll find out which dial peer is being matched on each one.
Then repeat the excersise removing the dial-peer to see which dial-peer works without delay.
Also, I see a prefix 5 on the first dial-peer (the "forward digits all" command could have work also) but I do not see a prefix 6 on the other pots dial-peer. Is that fine?
Hi Jadidisitel,
thanks for your answer, here is the result from the call active voice command:
With dial-peer 1 (4...)
Telephony call-legs: 0
SIP call-legs: 0
H323 call-legs: 1
MGCP call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 1
967 : 16444 -1232641072ms.1 +-1 pid:1 Answer 4199 connected
dur 00:00:00 tx:0/0 rx:0/0
IP 10.1.1.1:17806 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8 pre-ietf
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
SIP call-legs: 0
H323 call-legs: 1
MGCP call-legs: 0
SCCP call-legs: 0
Total call-legs: 1
Without the dialpeer 1 (4...)
Telephony call-legs: 1
SIP call-legs: 0
H323 call-legs: 1
MGCP call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
973 : 16450 -1232536202ms.1 +-1 pid:0 Answer 4199 connected
dur 00:00:00 tx:149/2942 rx:0/0
IP 10.1.1.1:19408 SRTP: off rtt:21ms pl:0/0ms lost:0/0/0 delay:70/260/10ms g729r8
973 : 16451 -1232536122ms.1 +-1 pid:6 Originate 6445 connecting
dur 00:00:00 tx:0/0 rx:149/2942
Tele 0/0/0:15 (16451) [0/0/0.1] tx:5520/2960/0ms g729r8 noise:-84 acom:6 i/0:-79/-79 dBm
SIP call-legs: 0
H323 call-legs: 1
MGCP call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
I think that the dialpeer is using the "calling number" instead the "called numer", and therefore it use the dialpeer 1 instead the dialpeer I want.
any ideas to resolve this problem?
thanks in advance
Hi again Carlos.
The show you posted seems weird, if you notice, there is only one leg on the first one, so I wonder if the call was connected at that time. Anyway, you can see that the in the first show the dial peer being matched is the (pid) 1 and on the second one it turns to be the default dial-peer 0.
So it has to do something with the dial-peer altough I do not see anything out of place there.
could you please wait till the calls are connected and paste the show again. Also, which IOS version are you running on both routers? Are you using an ISDN PRI between the routers?
Gracias
Javier
Hola Javier,
The IOS are:
Router A: 3640 12.1(5)T
Router B: 3825 12.3(11)T2
the routers are connected with a point to point line.
with dialpeer
SIP call-legs: 0
H323 call-legs: 1
MGCP call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
117F : 16650 -986312502ms.1 +26600 pid:1 Answer 4149 active
dur 00:00:12 tx:0/0 rx:0/0
IP 10.1.1.1:18722 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8
117F : 16651 -986302422ms.1 +16520 pid:6 Originate 6300 active
dur 00:00:12 tx:525/10462 rx:598/11730
Tele 0/0/0:15 (16651) [0/0/0.1] tx:28990/11820/0ms g729r8 noise:-57 acom:45 i/0:-43/-10 dBm
SIP call-legs: 0
H323 call-legs: 1
MGCP call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
without dialpeer
SIP call-legs: 0
H323 call-legs: 1
MGCP call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
119B : 16656 -986121432ms.1 +2530 pid:0 Answer 4149 active
dur 00:00:11 tx:216/4156 rx:278/5396
IP 10.1.1.1:18778 SRTP: off rtt:25ms pl:4960/0ms lost:0/0/0 delay:60/60/70ms g729r8
119B : 16657 -986121352ms.1 +2450 pid:6 Originate 6300 active
dur 00:00:11 tx:278/5396 rx:216/4156
Tele 0/0/0:15 (16657) [0/0/0.1] tx:14100/4210/0ms g729r8 noise:-64 acom:26 i/0:-60/-65 dBm
SIP call-legs: 0
H323 call-legs: 1
MGCP call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
thanks in advance
by the way I just change prefix 5 for forward digits all, and in the other dial peer it?s correct that the prefix 6 doesnt appear.
thanks
johncaston_2
Hi Carlos,
I'm assuming that you're just setting up IP Trunking between the two sites, each PBX and router with a E1/T1 interface?
What I would suggest is run "debug voice dialpeer" on each router. When you dial the phone number you should see the digits immediately appear on the local router. If the digits only appear after the 12 second delay I would suggest that the problem lies with the PBX, possibly trying to go via the PSTN first then reverting back to the E1 trunk when that fails. It could also be that the dial string is configured using the inter-digit timeout rather than specifying that anything that starts with 4 or 6 should go via the E1 trunk (could be 12sec timeout).
I've just done the same thing and it works correctly, the numbers are passed immediately to the router, once the dialpeer is matched, it's passed directly to the remote router.
Hope that helps, let us know how you get on
Cheers,
John
thanks for your fast answer John.
yes, the conexion between the router and the PBX is an E1 interface.
I ran a debug voice dialpeer on each router and the digits appear inmediatly in router A, and appear in router B as well. But the call need 12 seconds to initiate progress trough E1 in router B, but if I delete the dial-peer 1 in router B (dial-peer with destination pattern the calling number), it progress inmediatly. ??
Hi Carlos,
Sorry I didn't read your post properly. With Dialpeer 1 in place, when you watch the dialpeer debug what dialpeer does it match to?
If the number is 6xxx then it should only match dialpeer 6, so I don't see why dialpeer 1 would have any impact - very strange. Is it possible that PBX B is receiving the call and routing it back to Router B with a "4" prepended to it? - you should see those appearing in the debug as well. What happens if you remove the destination-pattern from dialpeer 1?
I don?t think that the PBX B is routing the call back, because there?s no communication between the router and PBX until those 12 seconds of delay.
these are traces with and without dial-peer (the trace without destination-pattern is the same that without dialpeer).
Notice than whith dialpeer 1, it take taht dialpeer, but without dialpeer 1, it takes dialpeer 0.
Thanks in advance
Hi Carlos,
port 0/0/0:0
m-gorbunov
Hello Carlos,
is the problem solved ? We had similar issue some time ago. In our case removing "req-qos..." statement from dial-peer config helped.
Mikhail
The problem was solved adding a prefix to the callingnumber in router A so in router B the calling number doesn?t match with dialpeer 1 (4...)
thanks to everybody
I belive the issue might have been resolved by simply adding a peer for incoming w. "incoming called-number ." for incomfing calls.
http://cisco.com/en/US/customer/tech/tk652/tk90/technologies_tech_note09186a008010e6d1.shtml
