Dial Plan for Hong Kong
ctohanG
I would like to create the dial plan of CCM 6.0 for Hong Kong, I searched the all cisco website, but there are no any result, May I know is there have any template or anything for Hong Kong.
Many Thanks!
5 Replies 5
rhugo
Level 3
Level 3
I can't speak too much about local dialing in Hong kong, so I googled it and found this item from the Fodor website, telling some specific dialing details:
http://www.fodors.com/world/asia/china/hong%20kong/travel_tip_2000098.html
Also, as far as country codes go, this is an excellent reference site that I use as well for understanding dialing patterns for most international dial plans: (the one I have referenced is an example call from USA / Midwest / Chicago, IL to Hong Kong)
http://www.timeanddate.com/worldclock/dialingcodes.html?p1=64&p2=102&number=
I hope this helps as a start.....
Thanks for your great help!!
Hang
You've probably sorted this by now...
But OFTA is the Hong Kong Telecoms authority.
They have a great numbering plan doc on their website.. actually one of the better ones I have seen. Complete enough to be able to build all the CCM route patterns required.
Check out:
http://www.ofta.gov.hk/en/numbering/no_plan/2008/200805.pdf
Cheers,
Tim
The link above to the numbering plan of Hong Kong is no longer working.
Today (March 7, 2012) this plan can be downloaded from :
http://www.ofta.gov.hk/en/numbering/main.html
