DID on 3640 Does not work
gene.alday
I've created a pots dial peer and enabled direct-inward-dial but any calls coming in gets a busy signal. Any ideas?
yraps
Please specify what is your ultimate goal?
Sending the calls to proper Call signaling Network point? IVR application etc...
Can you please attach the POTS dial peer and the VoIP one?
The goal is to have incoming calls to the dial-peer match another dial-peer for store and forward faxing. This is the first response I've gotten so I'll go into depth of what I am doing.
I have been able to get faxing to work, but every call that comes into the system goes through the fax IVR, 'select 1 for voice start for fax'. This is accomplished with the following, which works.
Dial-peer voice 1 pots
application detect_fax
destination-pattern T
information-type fax
direct-inward-dial
port 1/0:0
forward-digits all
What I would like to accomplish is replacing the above with the following so that any dialed number to 555500X goes through the fax ivr. Then all calls, say to the main office number 123-1234 goes to the application IVR as shown below, under the dotted lines.
dial-peer voice 1 pots
destination-pattern 555500.
direct-inward-dial
port 1/0:0
dial-peer 2 pots
direct-inward-dial
dial-peer voice 5000 voip
session target ipv4:10.5.1.4
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 5 mmoip
application fax_on_vfc_onramp_app out-bound
incoming called-number 55500.
session target mailto:$d$@detroit.com
mdn
dsn success
To system IVR
dial-peer voice 2 pots
destination-pattern 1231234
direct-inward-dial
port 1/0:0
dial-peer voice 1234 voip
codec g711ulaw
This doesn't work! With the direct-inward-dial the caller receives a busy signal
