did on cme problem
ird
Hi, trying to get direct access from pstn to internal extensions I used translation rules applied to dial-peers.
The problem is that with this configuration just one incoming call can be received at a time.
the following config is the one that I've tested, our 2821 router is connected to 4 isdn bri that have the public numbers routed and are in a jump group created by the telco, cme is ver 3.3.
Does anyone know which could be the problem?
Does anyone have a real working exemple?
thanks a lot.
greetings for that forum
configuration:
voice translation-rule 1
rule 1 /902321400/ /2000/
rule 2 /932183737/ /2000/
rule 3 /933683011/ /2100/
rule 8 /932388298/ /2800/
rule 9 /932388299/ /2101/
rule 10 /932388300/ /2301/
rule 11 /932388296/ /2500/
rule 12 /932388297/ /2601/
rule 13 /933683014/ /2701/
rule 14 /902116855/ /2702/
rule 15 /933683010/ /2703/
voice translation-profile als_2xxx
translate called 1
voice-port 0/0/0
compand-type a-law
cptone ES
connection plar 2000
voice-port 0/0/1
compand-type a-law
cptone ES
connection plar 2001
voice-port 0/1/0
compand-type a-law
cptone ES
connection plar 2002
voice-port 0/1/1
compand-type a-law
cptone ES
connection plar 2003
voice-port 0/0/0
compand-type a-law
cptone ES
voice-port 0/0/1
compand-type a-law
cptone ES
voice-port 0/1/0
compand-type a-law
cptone ES
voice-port 0/1/1
compand-type a-law
cptone ES
dial-peer voice 1 pots
translation-profile incoming als_2xxx
destination-pattern 0T
incoming called-number .
direct-inward-dial
port 0/0/0
dial-peer voice 2 pots
preference 2
direct-inward-dial
port 0/0/1
dial-peer voice 3 pots
preference 3
direct-inward-dial
port 0/1/0
dial-peer voice 4 pots
preference 4
direct-inward-dial
port 0/1/1
adignan
Level 8
Level 8
Its most likely that your carrier is not set properly to roll the next call over to the member of the trunk group.
please rate posts.
andy - berbee
Thanks, but when I use "connection plar" on the voice ports they can receive several calls at the same time, and the old telephony system worked well with this trunk.
