DIRT
mfrangipane
I am building a offline server to work on a UNITY/Veritas problem. I will be using DIRT to restore users to my lab UNITY. I have a license key which was issued by TAC, My question is do I have to have the same EXACT amount of users on the key that TAC gave me in order for the DIRT utility to work? I know if I have a lesser amount of users DIRT will not work but I have more then the actually UNITY then I am trying to duplicate will it work?
lindborg
No, the license key doesn't need to match exactly - if you end up restoring a database that has fewer licenses than you need, Unity will start barking about it in the event log, you wont be able to add stuff in the SA and eventually it'll go off line. DiRT, however, wont prevent you from restoring what you have.
