02-14-2002 08:35 AM - edited 03-12-2019 02:26 PM
Hello People,
Is it possible to totally disable the display on 7910's. Or better still just disable certain aspects. For instance if a user using an internal set(internal calls allowed only) dials another phone which is call forwarded to lets say a mobile number, the caller from the internal phone now sees that mobile number.
Basically I'm trying to curb users from inadvertently getting mobile or other numbers in this fashion.
Any help appreciated
Scuzzie
02-14-2002 10:14 AM
You could make the other user forward there calls to an Hoy Key number e.g. 6000 > 07973222555. That way there user will not see the moblie number and only the Hot Key
Rif
02-19-2002 08:47 AM
Unfortunately, there is no way to programmatically disable the display on any of the 79xx phones.
Dan Keller
Cisco Systems
