Disconnected calls using ISDN Gateway
daniel.asplund
Hi!
I'm using Ezenia's Encounter 3000 Gateway(version 1.0.1) together with Cisco MCM running in a C2500.
I have a problem with H323 endpoints calling via the Gateway to H320 endpoints. After 10 minutes the call disconnects. The same happens if I start a conference from the MCU and invites the H320 endpoint. But if the H320 endpoint is calling into the Gateway it is working fine.
So it only happens when a call is initiated from the inside and the call is always disconnected after 10 minutes.
Anyone got an idea why it is like that?
Cheers, Daniel
droessler
Maybe this will help:
CSCds42519 - Random reboots of IP/VC 3510, IP/VC 3520, and IP/VC 3525 units running version 2.1 software. Also, are the calls bonded correctly? What are you using for QoS - LLQ, etc. How is the bandwidth on your local net during the VC sessions?
