11-18-2008 06:07 AM - edited 03-15-2019 05:05 AM
I'm trying to use DMM 5.0.2 to push a DMP firmware upgrade from the server. I have done it before, but for some reason now when I go to create the "firmware upgrade" job I can't check the image on the list of "Available Assets". The checkbox just physically doesn't work. I have tried a couple of different browsers, to make sure it wasn't something browser-specific.
Anybody else seen this one? Is it just me?
Thanks!
Mike
11-25-2008 02:04 PM
What version of firmware are you running on the DMP?
How many DMP do you have, and how many are reloading?
How often are the DMP reloading?
12-22-2010 11:15 AM
I have the same issue. I have a DMM running 5.2.1, and I just installed a new DMP, out of the box with 5.1. So I tried the same thing.... First I went to DMP - Adv Tasks - Sys tasks, & created a new app for the firmware update, but it will not let me check the new firmware file that is sitting in the assets. I am new, and previously a firmware update had been done, and there is an App sitting there for the 5.2.1 update, but when I "edit" the application, it also shows no check in the box for the appropriate file. I don't know what to do at this point... will have to put a TAC case in. Let me know if you find the answer.
12-22-2010 01:21 PM
I don't remember exactly, but if memory serves the answer was embarrassingly simple. Just ignore the checkbox. The job will gray-in when you try to "check" it, and then just create/submit it.
Unfortunately my MCS went stupid last night or I'd verify it first-hand. But it does work.
