Document explaining routing method in CCM
meumeuh_toxin
Is there any document explaining the way the routing plans, route list, route group & patterns + the Calling Search spaces & the partition are all working together..
It is a bit confusing for me while reading the documentation I have.
thanks.
Aaron Harrison
Go to:
www.cisco.com/go/srnd
And look up the IP telephony SRND for whatever version of CCM you have. IN this there is a chapter on dial-plans that should tell you everything you need to know. More or less :-)
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
