E&M or FXO for PBX connection
tato386
Level 6
Level 6
Most of the example configurations that I see use either a E&M or FXO ports on the router to connect to the PBX/Key system. How do you know which to use? What is the difference between the two?
Diego
robrhodes
Level 3
Level 3
E&M is a trunk interface, either 2 or 4 wire, generally for switch-to-switch connections. E&M can support DID whereas FXO cannot. You're more likely to find E&M interfaces on a PBX than a key system unless your key system had analog DID lines.
An E&M i/f connects to another E&M - an FXO connects to an FXS.
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800a6210.shtml#Topic4
http://www.cisco.com/en/US/tech/tk652/tk653/tk754/tech_protocol_home.html
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a0080080afd.html#1133451
Is it correct to assume then that one would use E&M ports on a PBX or key system to connect to the PSTN? Can an FXO port connect to the PSTN in any way?
Diego
The most common interface will probably be an FXO. The issue is really cost. You may get more functionality from an E&M, but on a PBX you need the E&M trunk line card(s) rather than just a couple of station ports. The telcos, at least in my area, would rather not provision analog E&M. They're happy to sell you POTS (FXO on your side) or some flavor of T1.
