11-01-2005 12:50 PM - edited 03-13-2019 11:04 AM
I currently have a CCM 4.1(3) Publisher and I am trying to add a subscriber. The CCM disks I have are 4.0(2). My intentions were to build the subscriber and then use the web updates like I had done with the existing Publisher, but when I try to install with the 4.0(2) I receive a message that The CCM versions do not match and that it cannot continue.
When I researched the error it simply says to use the same version that is currently installed on the PUB. I was originally told that 4.1 disks were not available. Have they come available now and I need them for this or are there any work arounds?
thank you..
11-01-2005 01:34 PM
That's correct. You need 4.1(3) CDs to build Subscriber. Get the CDs from cisco TAC.
11-01-2005 02:07 PM
www.cisco.com/upgrade. Click on the link for Launch the Product Upgrade Tool and order your CDs online.
