Expressway outbound B2B calls fail
HeribertoVV
I'm working with Expressway v8.10 for MRA and B2B calls.  For B2B calls, I am able to be called from the outside (incoming calls succeed). But I am not able to call to the outside. Specifically, I want to call to WebEx and to Cisco Spark.
I have a DNS zone defined in Expressway-E and a search rule for this zone. Attached are the screenshots of the configuration.
These are the logs and the search history in Expressway-E:
Search (509)
State: Completed
Found: False
Reason: Not Found
Info: Policy Response
Type: SIP (INVITE)
SIPVariant: Standards-based
CallSerial Number: 74b2cec8-a66b-4d22-8b81-33a5449c89bc
Tag: e809e5a5-3b1e-4f34-921d-f2e9d159de57
Source (1)
Authenticated: False
Aliases (1)
Alias (1)
Type: Url
Origin: Unknown
Value: hvelazquez@mydomain.com
Zone (1)
Type: TraversalServer
Path (1)
Hop (1)
Address: 172.20.214.15:5061
Hop (2)
Address: 172.20.214.10:5560
Destination (1)
Alias (1)
Type: Url
Origin: Unknown
Value: sip:hv@xxx.call.ciscospark.com
StartTime: 2018-05-16 10:21:38
Duration: 20.68
SubSearch (1)
Type: Transforms
Action: Not Transformed
ResultAlias (1)
Type: Url
Origin: Unknown
Value: hv@xxx.call.ciscospark.com
SubSearch (1)
Type: Admin Policy
Action: Proxy
ResultAlias (1)
Type: Url
Origin: Unknown
SubSearch (1)
Type: FindMe
Action: Proxy
ResultAlias (1)
Type: Url
Origin: Unknown
SubSearch (1)
Type: Search Rules
SearchRule (1)
Zone (1)
Type: Local
Protocol: SIP
Found: False
Reason: Not Found
Duration: 0
Gatekeeper (1)
Address: 14.255.255.2:0
Alias (1)
Type: Url
Origin: Unknown
Zone (2)
Type: Local
Protocol: H323
Found: False
Reason: Not Found
Duration: 0
Gatekeeper (1)
Alias (1)
Type: Url
Origin: Unknown
SearchRule (3)
Zone (1)
Type: DNS
Protocol: SIP
Found: False
Reason: Request Timeout
Duration: 10.36
Gatekeeper (1)
Alias (1)
Type: Url
Origin: Unknown
Zone (2)
Type: DNS
Protocol: H323
Found: False
Reason: Resolution failed
StartTime: 2018-05-16 10:21:58
Duration: 0.11
Gatekeeper (1)
Alias (1)
Type: Url
Origin: Unknown
tvcs: Event="Call Rejected" Service="SIP" Src-ip="172.20.214.15" Src-port="25003" Src-alias-type="SIP" Src-alias="sip:hvelazquez@grupofrisa.com" Dst-alias-type="SIP" Dst-alias="sip:heriberto.velazquez@entercs.call.ciscospark.com" Call-serial-number="74b2cec8-a66b-4d22-8b81-33a5449c89bc" Tag="e809e5a5-3b1e-4f34-921d-f2e9d159de57" Detail="Not Found" Protocol="TLS" Response-code="404" Level="1" UTCTime="2018-05-16 15:21:58,884"
My Expressway-E has advanced networking (two interfaces). I try DNS Lookup and it shows SRV and type A records for the domains I tested. I tested with my Cisco Spark account and with 6656109786@b2b.ciscotac.net (Cisco TAC B2B call tool).
HeribertoVV
attached are the configuration files.
Never got a response, eh? Bump
Prashant Sharma
Hello HeribertoVV
This thread look so old but since no replied and looking your issue explained suspected an issue of firewall.
Did you check if there was any packet inspection behind this?
Prassha3
