11-12-2001 12:26 AM - edited 03-12-2019 01:17 PM
I have a callmanager 3.1(1) with extension mobility installed on the same server. I changed the IP address of this machine, but now the e.m. doesn't work anymore. If I fill in my userID and PIN it's requesting for a long time, and then authentication unsuccesfull. I changed all settings in AppAdmin, like Jtapi and directory, the engine runs.
Does someone has a clue?
Thanks for any help.
Sascha
11-12-2001 05:18 AM
Set the ConnectMode bit Number 4 to "1". i.e. "00060010".
Good Luck
Mehmet
11-12-2001 06:29 AM
But where can I find that setting?
Sascha
11-12-2001 06:32 AM
isn't it ATA 186 setting??
11-12-2001 06:39 AM
Hi Sascha,
i think that is a mistake...my response was for an other question..
sorry
mehmet
11-12-2001 08:04 AM
Sascha, when you install the CRA components one of the install options asks about the server location. Can't recall whether this applies to the EM part or not, but if it does then this looks like the problem.
Rory
11-19-2001 12:01 AM
Hi all,
We have found the problem.
When installing the Extension Mobilty the ip-address of the callmanager is in a entry of DC directory,
cisco.com - CCN - systemProfile - Hoteling Profile
in here is the URL to the login.asp on the ccm.
(thanx Cas!)
Sascha Monteiro
