04-08-2004 11:36 AM - edited 03-13-2019 04:35 AM
I would like to huck up a external CD Player for our MOH with CM 3.3.3.
How would I do that ?
TIA
04-09-2004 07:34 AM
There are a couple of ways to do this.
1) If the server you are running CCM on has a PCI card, you can install a SoundBlaster card and connect the cd player to the line in.
Here's a link with some information;
2) You can use an external USB sound import device, such as the Telex Communications P-800 USB Digital Audio Converter. This connects to a USB port on some of the newer MCS servers and is basically a USB sound card. Note that this device is not supported by TAC. Search the forums, and you'll see a few people using this device.
tm
04-09-2004 09:55 AM
It may not be TAC supported but atleast in the OS 2.5 Release Notes is says it is supported (or atleast tested by someone at Cisco at some point):
"Support for the Telex P-800 USB sound device to support music from an external source for the Music on Hold feature in Cisco CallManager on the MCS-7825H-2.2-EVV1, MCS-7835H-2.4-EVV1, MCS-7835I-2.4-EVV1 MCS-7845H-2.4-EVV1 and MCS-7835-1266 platforms"
