07-09-2007 04:54 AM - edited 03-15-2019 04:52 AM
How can I extract the CDR from a CME, if i don't have a CVM. I wanna use it with a mySQL Database.
Thank you.
07-26-2007 12:13 PM
checkout qqCDR from ooglenetworks (http://www.ooglenetworks.com/)
David.
07-26-2007 10:19 PM
Thanks for the reply,
qqCDR is very good, but I think it runs in Windows.
1- Is there any solution if I use Unix/Linux platform?
2- Is there any method to extract/read the CDR of the router?
Thks
07-30-2007 05:18 PM
Thanks for the plug, David.
I'm the author of qqCDR. It is capable of pulling from CallManager, but not CME (unless there is a SQL interface that I don't know of - somebody emailed me asking just this question, I'm looking into a way to possibly code a solution around CME once I get a little more info. The last I knew, CME could only spit out CDR to syslog, for later parsing. Has this changed?
