08-03-2006 08:24 AM - edited 03-13-2019 02:27 PM
Is there a way to have a phone forward to another phone after 4 rings rather than go to voicemail.
We are using CCM 4.1.(3)sr2 & have 7941 IP phones
Solved! Go to Solution.
08-03-2006 08:28 AM
In CCMAdmin go to Device --> Phone, select the phone that you want to forward, go to the line and under Call Forward and Pickup Settings, put the extension in the Forward No answer or Forward Busy according of what you want in the Coverage/Destination field. Make sure that the VM box is NOT checked
08-03-2006 08:30 AM
you can setup the phone to callForwardNoAnswer to another phone in the phones Device Configuration within CCM Admin.
on the phone that you want forwarding to happen:
1) goto the line configuration page of the phone
2) under the "CallForward and PickupSettings" section, enter the extension to be forwarded too in the 'coverage/destination' field of the CFNA fields. (set a proper CSS if required)
3) uncheck the box to the left of the field if it is checked. (this prevents the call from going to voiceMail)
4) update the phone config and test.
08-03-2006 08:26 AM
Just put the extension of the phone instead of checking the VM box in the phone configuration
08-03-2006 08:28 AM
08-03-2006 08:30 AM
08-05-2006 10:05 AM
hi ,
On the ephone-dn you just have to declare
call-forward noan XXX timeout 10
where XXX is another phone extension , and timeout 10 is equivalent to 10 secs, just enough time for 4 rings before get redirected to XXX
best, regards
Luis Oberto
