Gateway reboot and isdn outgoing display-ie
aalejo
Level 5
Level 5
After a CMM reboot the command
"no isdn outgoing display-ie" appears again and must be changed manually to "isdn outgoing display-ie".
Any ideas?
Alex
adignan
Level 8
Level 8
Are you using MGCP? If you are "ccm-manager config" is overwriting that command back to the default. I would suggest doing a "no ccm-manager config". However, be aware that changes you make in the CallManager interface then will no longer change the gateway, that will have to be a manual process.
I am using H323.
Alex
