GUI on CME4.0 with CUE general question
ReadersUK
Level 2
Level 2
when logging on to the GUI using http:/x.x.x.x/Web as a general user. There is a
Search > Local Directory Search
option on the menue, however it just shows a list of extensions and names but no search facility is this correct or do i have a problem with GUI?
Colin
paolo bevilacqua
Hi again Colin,
it's not you that have a problem, it's the GUI that have a problem in delivering features :)
Thanks again, its very disapointing, i think it would be better if this was not shown in the gui and not raise expectations.
colin
