07-09-2014 01:22 AM - edited 03-13-2019 08:35 PM
Hi All ,
i have H323 gateway , in comming calls for Stonefax are not working .
Calling Number : 36401984
Called number : 878
Debug Voice CCapi ino attached .
07-09-2014 09:14 AM
Looks like the call first matches dial-peer 22 and the remote end sends a network out of order. Then it goes on to try dial-peer 9 which sends a recovery on timer expiry. I would check the remote side and see why its not responding.
07-15-2014 02:45 AM
HI
As per your logs the cause-code= 38 which means network of order. Kindly check the below:-
dial-peer voice 22 voip
session target ipv4:172.20.21.24
progress_ind setup enable 3
progress_ind progress enable 8
Check with other stonefex why they are unable to accept 1720 . Try without 1721.
please rate all useful information
