hardware matrix for 2600
justin.donoghue
Hi I hope you can help.If I have a 2651XM with an AIM voice 30 and an NM-HDV-2V installed can I populate the module with a VWIC-1MFT-E1 AND a VIC2-2BRI?AND more importantly will it work? I just want to do voice all the way ie the E1 card will interface with a PBX and the VIC BRI will be going out the PSTN.Any opinions appreciated.
Not applicable
The following document is about the hardware compatibility Matrix for 2600 Routers:
http://www.cisco.com/en/US/products/hw/modules/ps3129/products_tech_note09186a00800ae37f.shtml
yeah I had found this document and it made it a bit clearer.thanks
