HDA and 3640 with MGCP Call Manager ver 3.2.2c
t.guerriero
I am running Call Manager 3.2.2c and have a 3640 (12.2.11T) with an HDA analog card. I am using MGCP and have no issues with the PRI (on a 2T1) but I cannot use the HDA . I assume I must use H.323 in order to use the HDA. Is it possible to run both MGCP and H.323 on the same gateway? If so how do I accomplish this.
Any feedback would be appreciated.
I think service pack C for 3.2.2c adds support for the HDA using MGCP
tringwelski_2
I have the same config, and have the HDA working via mgcp fine, but I cannot get the PRI to register, any suggestions? send me an email: tringwelski@forsythesolutions.com
TR
I think if you try 12.2.11 T you should be all set. I had the same issue and when I changed to the newer version, the issue went away.
How did you get the HDA card to register? I don't even have an option to use the HDA.
