Hi... are you after a gateway config or the callmanager side?
Have you configured your attendant DN on the CM?
Basic config for the gateway is the same as a PRI minus the bind-l3 stuff... Put in the usual MGCP/ccm-manager commands, then create a dial-peer pointing to each port with application mgcpapp in it...
Aaron
Aaron
Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
