High density analog FXO gateway
jaregalado
What is the best voice gateway that is capable of supporting 30 FXO ports on the same chassis (if such a device exists).
I just read the NM-HDA network module supports up to 8 FXO ports so I will need 4 of these modules if this is the only option available.
It is needed to connect 30 tellular devices to the VoIP network.
Thanks for your advice.
dgahm
Level 8
Level 8
Considering the high cost of the HDAs and a router to handle 4 of them I would opt for 2 channel banks connected to T1 CAS ports set for FXO signalling.
Here's a channel bank that would work:
http://www.voipsupply.com/product_info.php?products_id=921
Please rate helpful posts.
thisisshanky
Level 11
Level 11
Cost is a very big issue. I would suggest going with what dgahm suggested.
If you use a 3845 which has 4 NM slots and put 4 NM-HDAs, each NM-HDA can home 8 FXO lines. So the max you will get is 32 FXO ports. I have not tested this configuration, so I am not sure if 4 modules will work perfectly with out any issues on a 3845. Considering the cost of a 3845 plus 4 NM-HDA modules, plus 2 daughter cards per NM-HDA and also a DSP chip required per network module...sounds like a lot of money for 30 FXO port solution.
PS: Please remember to rate helpful replies!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Yes, the HDA option seems very expensive, so I will consider the Channel Bank option.
Thanks a lot for your replies.
Regards.
