How can I create a BRI loop testing cable.
silvakizir
I've managed to create a PRI loop for testing purposes of the interface in a RJ45 Jack Plug by connecting a wire from PIN 1 to PIN 4 and a wire from PIN 2 to PIN 5 and it works perfectly.
Does anyone know how to make a testing BRI loop cable?
I've connected a wire from PIN 3 to PIN 4 and Wire from PIN 5 to PIN 6 with no success.
I've also tried a connection with a wire from PIN 3 to PIN 5 and from PIN 4 to PIN 6 also with no success.
RJ-45 Jack PlugRJ-45 Jack Plug
Singh2471
Singh2471
You may also try below link:
https://wiki.freepbx.org/display/PC/B500+Installation#B500Installation-BRICableWiring
hope this help!
Thanks!
