634
How can unity connection users change voicemail box pin?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-03-2011 01:44 PM - edited 03-13-2019 07:33 PM
Installation is CUCM5000BE 8.6.1. Users want the ability to change their voicemail box pin?
They can't do this via preference in the users voicemail box option.
How can this be done easily?
Feisal
Labels:
- Labels:
Other Collaboration Topics
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-04-2011 04:40 AM
They can use PCA for such task.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-11-2011 02:01 AM
Thanks Java,
I didn't go with PCA but changed the default policy to allow user to change pin and then did a bulk reset pin.
