How can unity connection users change voicemail box pin?
feisalb
Installation is CUCM5000BE 8.6.1. Users want the ability to change their voicemail box pin?
They can't do this via preference in the users voicemail box option.
How can this be done easily?
Feisal
Jaime Valencia
They can use PCA for such task.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Thanks Java,
I didn't go with PCA but changed the default policy to allow user to change pin and then did a bulk reset pin.
