incoming and outgoing translation
ciscoforum
does gateway support incoming translation? cisco document says it support both. But under dial peer voice voip or pots, there is only translate-outgoing option, no incoming. Thanks
There is a hint indeed. An incoming calls coming through a pots dial peer is send to the CCM via a voip dial peer.
So for the router,gateway it is an outgoing call on the voip dial peer.
If you want to make a transformation on an incoming call youe have to create your rule and apply it on the voip dial peer(s) :
for example to add a '0' as prefix for incoming calls
translation-rule 2
Rule 0 ^1 01
Rule 1 ^1 01
Rule 2 ^2 02
Rule 3 ^3 03
Rule 4 ^4 04
Rule 5 ^5 05
Rule 6 ^6 06
dial-peer voice 40 voip
destination-pattern [1-9]...
progress_ind setup enable 3
translate-outgoing calling 2
voice-class codec 1
voice-class h323 1
session target ipv4:X.X.X.X (real IP address removed here)
dtmf-relay h245-alphanumeric
regards,
Marc
rnarayana
Level 5
Level 5
For incoming translation you cannot apply on the dial-peer .You need to do as follows
For Voip use the following command
voip-incoming translation-rule called | calling < rule numeber>
For incoming pots you have to apply under voice ports as follows
voice-port <>
translate calling | called
I hope this helps.
RAdhika
translation-rule 2
Rule 0 ^1 01
Rule 1 ^1 01
Rule 2 ^2 02
Rule 3 ^3 03
Rule 4 ^4 04
Rule 5 ^5 05
Rule 6 ^6 06
voice-class codec 1
voice-class h323 1
regards,
Marc
I have tested the incoming translation under voice-port, it works perfect. I'll test this translate-outgoing also, thanks guys.
