04-13-2002 10:33 AM - edited 03-12-2019 03:06 PM
New to call manager. We have an existing ip telephony setup that allows outgoing calls through a pbx. We are getting rid of the pbx and have a pri t1 with did's. The pri comes into a 3640 gateway which is connected to the call manager which is on a ics7750. which has an mrp. What do i need to do to allow incoming calls through the pri on the gateway and on the mrp and the call manager. any tips and/or links would be greatly apppreciated
04-21-2002 05:21 PM
Often times complex configuration issues are best addressed in an interactive session with one of our trained technical assistance engineers. While other forum users may be able to help, its often difficult to do so for this type of issue.
To utilize the resources at our Technical Assistance Center, please visit http://www.cisco.com/tac and to open a case with one of our TAC engineers, visit http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
04-24-2002 01:03 AM
Did you fixed the config. If not let me know, we are able to fix it.
Christoph
