Innoculate IT incompatibility with CCM 4.0.1
a.seetharaman
I am running 4.0.1 with all the latest patches updated. In our organization, we are using Innoculate IT as the Anti-virus software. But when I install AV in the CCM, the CPU utilization is shooting to 90% and abover frequently. Is there any problem or incompatibility of Innoculate with CCM 4.0.1.
The same anti-virus software was working earlier with CCM 3.2.3 version.
Appreciate if someone can help me on this.
Seetharaman.
thisisshanky
Level 11
Level 11
Seetharaman,
There are only a few Antivirus software that are supported with CCM. You can find the list of third party agents/software that are supported currently by CCM in this link.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_bulletins_list.html
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Thanks for the link.
Is it that the AV not mentioned in the list should not be installed?
Seetharaman.
