Intercom ASP Sample
mattiep00
Just wondering if anyone else out there has successfully got their Intercom ASP service to close the connections when one user presses Exit? I have been trying this for a while, and don't know how to send a remote RTPRx:Stop
All help appreciated!!
26 Replies 26
I have been able to get the service to work great in our main office, but if I try to use it to intercom another office on the WAN the audio does not transfer (the speaker and mute buttons will activate though) I am connected to this remote site via Frame Relay, is this the reason I am not able to use the service to talk to these sites? Thanks
Is multicast enabled on all your interfaces?
ip pim sparse-dense mode
It wasnt, so I went ahead and did that following this document:
http://www.cisco.com/univercd/cc/td/doc/cisintwk/intsolns/mcst_sol/frm_rlay.htm#99498
I followed the example configs for point 2 point subinterfaces and I still get the same results, no voice. Any other ideas? I'm no expert so I may have overlooked something. Thanks again.
So the question still stands. How do we turn off the Receive port on the remote phones once we press the exit button on our transmitting phone? Can we put multiple URL's in the one URL tag of the button we press?
I guess we could make another page that just closes the IPs and ports forwarded to it. So we could collect the IPs and ports from this script and use them as variables being passed to the URL we're calling, and all that web page does is execute the push to RTPMRx:Stop of those phones IPs.
Sound good? I'm going to work on that.
Szia,
Mark
sisqocracker
Here's a working version where it does close the session once you're done. It does this via pulling a second web page which closes those sessions. It then has the final Exit button on that page.
First file is the intercom, which has been changed from a 'Text' to a 'Menu', this allows us to kick off another page. the second page allows you to return back to the intercom or just exit out.
The second page is the page that stops the remotes from listening. Enjoy!
<%@ Language=JavaScript %>
var pushuserid = "ipservicesdk";
var pushpassword = "cisco123";
Response.ContentType = "text/xml";
Response.Expires = -1;
//Declaring Variables
ipAddr = Request.ServerVariables("REMOTE_HOST");
toIPAddr1 = "10.128.40.74";
toIPAddr2 = "10.128.40.108";
toIPAddr3 = "10.128.40.68";
// Starting the Transmission
phonePush(ipAddr,"RTPMTx:Stop",pushuserid,pushpassword);
//phonePush(ipAddr,"RTPMTx:239.0.0.45:20482",pushuserid,pushpassword);
// Start the Receiving on the first terminal
phonePush(toIPAddr1,"RTPMRx:Stop",pushuserid,pushpassword);
phonePush(toIPAddr1,"RTPMRx:239.0.0.45:20482",pushuserid,pushpassword);
//Start the Receiving on the second terminal
phonePush(toIPAddr2,"RTPMRx:Stop",pushuserid,pushpassword);
phonePush(toIPAddr2,"RTPMRx:239.0.0.45:20482",pushuserid,pushpassword);
//Start the Receiving on the third terminal
phonePush(toIPAddr3,"RTPMRx:Stop",pushuserid,pushpassword);
phonePush(toIPAddr3,"RTPMRx:239.0.0.45:20482",pushuserid,pushpassword);
Office Intercom
Press and Hold to Talk
Talk to Group
Stop Talking to Group
Talk
RTPMTx:Stop
Shout
RTPMTx:Stop
Mute
RTPMTx:Stop
Quit
http://10.128.13.186/ciscoipservices/intercom/stopintercomgvl.asp
//phonePush(toIPAddr1,"RTPMRx:239.0.0.45:20482",pushuserid,pushpassword);
//phonePush(toIPAddr2,"RTPMRx:239.0.0.45:20482",pushuserid,pushpassword);
//phonePush(toIPAddr3,"RTPMRx:239.0.0.45:20482",pushuserid,pushpassword);
Office Intercom
Returning to Intercom?
Return
http://10.128.13.186/ciscoipservices/intercom/newintercom.asp
Exit
SoftKey:Exit
Thanks.
Szia,
Mark
I found this post, used the script and it worked!!
One more think to ask though.
Is it possible to have the Talk buttom on the target phones?
If you guys have the script please let me know.
Thank you.
Zeek
Yes, it is possible to have Talk button on the target phone to make it sort of push to talk application. All you have to do is to add a softkey with RTPTx URI.
Thanks for your reply.
I'm not really good at scripts, so i'd rather copy and paste one and maybe make changes, but i don't really know how to add a softket to the script i already have.
This is the script i use to intercom multiple ip's.
Please let me know if you know the way to add the reply key.
var pushuserid = "push2phone";
var pushpassword = "12345";
toIPAddr1 = "192.168.128.53";
toIPAddr2 = "192.168.128.68";
toIPAddr3 = "192.168.128.56";
toIPAddr4 = "192.168.128.171";
toIPAddr5 = "192.168.128.59";
toIPAddr6 = "192.168.128.60";
toIPAddr7 = "192.168.128.58";
toIPAddr8 = "192.168.128.56";
phonePush(toIPAddr4,"RTPMRx:Stop",pushuserid,pushpassword);
phonePush(toIPAddr4,"RTPMRx:239.0.0.45:20482",pushuserid,pushpassword);
phonePush(toIPAddr5,"RTPMRx:Stop",pushuserid,pushpassword);
phonePush(toIPAddr5,"RTPMRx:239.0.0.45:20482",pushuserid,pushpassword);
phonePush(toIPAddr6,"RTPMRx:Stop",pushuserid,pushpassword);
phonePush(toIPAddr6,"RTPMRx:239.0.0.45:20482",pushuserid,pushpassword);
phonePush(toIPAddr7,"RTPMRx:Stop",pushuserid,pushpassword);
phonePush(toIPAddr7,"RTPMRx:239.0.0.45:20482",pushuserid,pushpassword);
phonePush(toIPAddr8,"RTPMRx:Stop",pushuserid,pushpassword);
phonePush(toIPAddr8,"RTPMRx:239.0.0.45:20482",pushuserid,pushpassword);
Office Intercom
Talk to Group
Talk
RTPMTx:Stop
Shout
RTPMTx:Stop
Mute
RTPMTx:Stop
Quit
http://172.16.1.15/ciscoipservices/ASP/intercom/stopintercomgvl.asp
This type of broadcast isn't meant or designed to be two way. Because I have created a second page, this could be leveraged to make something that works in the other direction, but it would be static like this is designed to be. Where you can only respond to something that is hard coded. I don't have the time for it right now, but can work on it before a whole lot longer. Holidays are coming up, usually a slow time and can write code. But it isn't as easy as adding a button.
Glad I could help people with what I had done so far (along with the original contributers).
Mark Cooper
Thanks for the script. I did try it and I can get the phones to go off hook but no audio on my local LAN. Any suggestions?
Thanks for the script at least I know it almost works. What I had a question on is if someone knew how to load the devicelist.xml from call manager and then let it get the IP addresses, if the array in the asp file has the SEP0123456789456(mac) address in it.
We are trying to create a way to add phones without knowing the IP address. Also the devicelist.xml file is updated from callmanager every hour.
Here is the code I have let me know if I made a mistake. Thanks
var devices = new Array;
//declares device list
devices[0] = "SEP012345678943"; //Scott
devices[1] = "SEP012345678945"; //Test1
devices[2] = "SEP012345678944"; //Test2
function getXMLDoc (file) {
var xmlDoc = new ActiveXObject('Microsoft.XMLDOM');
xmlDoc.async = false;
xmlDoc.load(file);
return xmlDoc;
var xmlDoc1 = getXMLDoc('devicelist.xml');
//Get the IP's for each device.
for (var i=0; i
XMLNode = xmlDoc1.selectSingleNode("/DeviceList/Device[@n='" + devices[i] + "']/@i");
if (XMLNode == null)
ips[i] = "";
else
ips[i] = XMLNode.value;
// Parse the IPs and remove the requestor and any non-existant.
var parsedIPS = new Array;
for (var i=0; i
if (ips[i] != thisIP) {
if (ips[i] != "") {
parsedIPS[parsedIPS.length] = ips[i];
No idea why but My phone open the sript as a text, any idea why ?..I feel newbie on that.
