Interrupt Idle script by entering number
raemdonp
I have successfully put the compnay logo with the idle functionnality of CallManager on a IP Phone. The only issue is that I have to press "Exit" softkey to stop the idle.asp script and start to dial a number. The end users don't like this method to start to dial a number.
Have you any idea which command on my .asp script or another way to interrupt the script when the system detect that you are starting to press number buttons on your IP Phone ?
Thanks for your help.
Pascal
Yes, I had a look but nothing seems to correspond to my issue. In fact, I can interrupt the idle script by pressing "Exit" softkey, by taking a line (with the right button) or by picking up the handset.
But I wannted to interrupt it by pressing one of numbers keys.
