IP IVR voice Prompt audio format
jennyp
I'm currently writing an IVR Script, and I want to know if it is posible to change the Prompt audio format from CCITT u-law 8 KHz, 8Bit, Mono 7 kb/sec, to another format like GSM 6.10, and still be playable from the IVR.
Or if there are any cisco java classes that I could call from my IVR script to change the audio format of a file from GSM to CCITT u-law? Or a third party tool CLI that could do the trick that you recommend?
15 Replies 15
You will need to save as ccitt-ulaw from a format that be recognized by the player (check into Sound Forge by Sonic Foundry). I would recommend that you record in 16 bit and save as the ccitt format (8k bandwidth, 8 bit mono). If you need fancy fades (music under voice) or other conversion services I can help you. other than thta go to mono and re-record as 16 bit, then down convert. You will lose some quality, but in a pinch if you cannot re-record, go analog.
