06-08-2005 05:49 AM - edited 03-13-2019 09:24 AM
Does the 7912 support more than two Calls in CallManager 4.1?
Solved! Go to Solution.
06-14-2005 01:17 PM
Yup. Tested both incoming and outgoing. Works like a charm.
The interface and behaviour of the phone display when there are multiple calls in play however has quite a bit to be desired though. I didn't like it.
You should really test in a lab to see how it might fit in your environment, i.e. phone upgrades are required.
Lelio
P.S. Don't forget to rate posts if they help you out
06-14-2005 06:18 AM
This URL might help you:
http://www.cisco.com/en/US/products/hw/phones/ps379/products_qanda_item09186a00800a6763.shtml
06-14-2005 09:00 AM
Nothing about 7912
06-14-2005 10:27 AM
I've got a copy of 4.1.3 running in the lab.
7912 DN configuration screen has similar multiple call/call waiting configuration options as the 7940.
Multiple Call / Call Waiting Settings
Maximum Number of Calls* [ ] (1 - 6)
Busy Trigger* [ ] (<= Max. Calls)
Only difference is a 7940/60 has a max of 196 calls.
06-14-2005 11:31 AM
And works? Did you tested?
Sometimes IP Phones have configurations for future load release.
Alex
06-14-2005 01:17 PM
Lelio
