ip phone can't fallback to SRST when phone lost connect to CCM before fallback to SRST
Tom Yan
          HI everyone, I have encountered one question :ip phone  can't fallback to SRST when phone lost connect to CCM before fallback to SRST.
I want to know whether SRST FEATURE not support this environment. Thanks a lot !
Jaime Valencia
Have you properly configured SRST and have you configured the SRST reference in CUCM and applied it to the phone via the DP???
java
if this helps, please rate
Jaime Valencia
java
thank you for your reply.
