03-19-2002 03:58 PM - edited 03-12-2019 02:52 PM
I have not been able to get the IP Phone Services to work on a separate IIS server running 4.0 with the SDK software. I have been successful at getting them to run on the CallManager, and then I tried to move the entire directory structure over to my new IIS server and set it up exactly as the callmanager was setup. I now receive an error on the phone "Error -7ff5fe53: Automation server can't create object". I just want to know who has had this problem before and how did you fix it?
CallManager 3.1
NT server 4.0 with IIS 4.0
Service pack 6.0
SDK 2.0
03-24-2002 07:06 PM
Although I personally have not tried to use the IP Phone Services SDK on WinNT before, I do know that certain components need to be registered on the server in order for them to work. So you can't just copy over the files from one server to another and expect them to work.
You need to run the SDK installation on the desired server. Then you can copy over whatever file(s) you modified on the original box.
03-25-2002 01:12 AM
I have had the same problem on Win2000, Ive not managed to fix it yet.
