IP Phone Services SDK LDAPSearch filter
I would like to add an LDAP Search filter so that only AD user objects with an ipPhone value will be displayed on an IP Phone's corporate directory - using an IIS server so that I can query AD and span multiple child domains without being restricted by CUCM appliance to only 5 directory associations.
Attached is an example code provided by the Cisco IP Phone Services SDK but don't know how to add the LDAP filter on the ipPhone attribute.
Any ideas?
19 Replies 19
superjay007
You've done a fantastic job with the script so far.
Thought you might like to know I couldn't get it working on Server 2003 with IIS6. When I moved the scripts to IIS7 on Server 08 with AD, the LDAP query worked first time.
Regards.
Jamie
Hmm... I wrote it on 2003 originally. I guess it's a difference in the security setup in IIS, there's not much to the code :-)
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
I've been looking for this all over. Would this work with an authenticated bind to an ldap server? If so, which paramter do I update to enter the LDAP user and password?
Any help would be appreciated. Thanks in advance.
Generally what I do is set the application in IIS to run under the account you want it to use - this can be a standard account by default (i.e. a normal, non-admin user has rights to read all that is required in AD). Setting it this way means you don't have to enter it into any text/config files, just the IIS dialog boxes.
On a domain-member machine you can just run it under an AD account directly.
On a non-member server you would have to create a local account with the same exact username/password as an equivalent domain account, and run it under that. It should passthrough authenticate the two.
Aaron
does this script work with openLDAP? because i'm still looking for the script that work not only with AD but also with OpenLDAP.
