IP Phones not registering in CME
quytx
HI every one
Please help me fix this error. i have a problem when sip phone, and soft phone 3cx cant register to CME.
This is my log and my config on CME router 4331. When phone register. CME send 503 Service Unavaible
*Sep 29 04:28:28.331: %SYS-5-CONFIG_I: Configured from console by consoleow run
Building configuration...
Current configuration : 3031 bytes
! Last configuration change at 04:28:28 UTC Sat Sep 29 2018
version 15.5
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
card type e1 0 1
enable password cisco
no aaa new-model
ip dhcp pool voice
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
subscriber templating
isdn switch-type primary-net5
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
mode border-element license capacity 200
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip refer
signaling forward unconditional
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
voice register global
mode cme
source-address 192.168.1.1 port 5060
timeouts interdigit 5
max-dn 70
max-pool 3
authenticate realm all
create profile sync 0003973807045444
camera
video
voice register dn 2
number 202
allow watch
name 202
voice register pool 2
id mac 2222.BBBB.1234
number 1 dn 2
username 202 password 202
codec g711ulaw
voice-card 0/1
no watchdog
license udi pid ISR4431/K9 sn FOC2228206T
redundancy
mode none
controller E1 0/1/0
clock source line primary
pri-group timeslots 1-31
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
negotiation auto
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/3
no ip address
shutdown
negotiation auto
interface Service-Engine0/1/0
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp tlv app
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
control-plane
voice-port 0/1/0:15
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
telephony-service
max-ephones 10
max-dn 10
ip source-address 192.168.1.1 port 2000
max-conferences 8 gain -6
transfer-system full-consult
sip-ua
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password cisco
login
end
9 Replies 9
quytx
check the step by step configuration
https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-express/99946-cme-sip-guide.html#configs
Look at the Logs in CME while registering time,
you getting error registrar is not enabled from 192.168.1.1
BB
Yes 192.168.1.1 is CME. File attach is log from softphone
HI Bandi
Do you have step config with thirdparty softphone register to CME. I am using hardware panasonic phone and softphone 3cx
As i have suggested you have registrar config missing.
here is the good example for you to step by step :
http://www.ipbalance.com/voip/voip-cucme/1157-how-to-configure-free-sip-phone-x-lite-on-cisco-cme86.html
here is good thread for you CME with x-lite(standard softphone in the market to use for PC).
https://community.cisco.com/t5/ip-telephony-and-phones/register-a-sip-device-with-cme/td-p/791112
BB
Thanks Bandi, i will read and try. i will feedback to you soon if that ok
No problem..hope it will resolve your issue.
BB
Hi every one, i have been fixed it. Thank you evey one :)
Thank you for the feedback.
BB
