08-15-2001 02:08 AM - edited 03-12-2019 12:15 PM
Hi,<br><br>Everytime the CCM boxes are rebooted or a new phone is installed the phone resets to the default full-volume for the ringer. Is there any way to reset this default ringer volume to a lower value?<br><br>Also, on the same subject, the default dial-tone on the phones is a bit loud also. Is there any way to lower the default dail-tone volume?<br><br>Thanks in advance!<br><br><br><br><br>
08-15-2001 02:08 AM
This forum is geared towards Unity Voice Mail. The problem you describe is a CallManager issue. There might be some one out there that can provide an answer, but you might want to check out this forum...
http://www.cisco.com/go/netpro/
Steve Olivier
Software Engineer
Cisco Systems
08-21-2001 08:42 AM
To keep the volume settings in the IP Phone do the following.
1. From a 7960 ip phone for example press settings-->ring type--> scroll down the screen and find the ring tone that you want press--> ok--> save. It is important to press the save key otherwise the effort is lost. This will save all volume setting. Handset, ringer, speaker, ect...
If you go to www.globalknowledge.com
there is a CIPT Access (forum) that fields questions such as this one.
