ISDN BRI NT and VoIP
I have a problem with VoIP over ISDN BRI connection in the following configuration:
phoneA--PBXa--routerA======routerB--PBXb-phoneB
Connection between routers and PBXs is made by ISDN BRI using VIC-2BRI-NT/TE in routers.
Ports BRI on routers are configured as NT (network side).
Routers are connected together with leased line (2Mb/s).
When phoneA initiates voice call to phoneB following is happened :
1. routerA transmits VoIP packets to routerB,
2. routerB transmits one SETUP frame (ITU Q.931) to PBXb; after 4 seconds next SETUP
frame
3. PBXb is not responding
4. after few seconds routerA transmits DISCONNECT to PBXa with cause=0x80A2 No circuit/channel available
Transmitted numbers are correct. Layer1 and 2 - correct.
If anybody is interested - I have logs from debug isdn q931 and debug voice ccapi inout.
Thank you for any suggestions.
Przemo
dgoodwin
The log of debug isdn q931 on routerB would be helpful here. But I am thinking that we need to figure out why when we send a Q.931 SETUP message to the PBXb that it does not respond. Most likely the problem is there.
sarvesh.mishra
We would like to know we can enable load balancing & Dial backup between two unequal cost links in 1750 router or not. We are using ISDN BRI and Leased line and a choice of OSPF,IGRP & EIGRP.
lferre
could you post the configuration of your router?
yuenme
Send me the trace and config files and I can take a look at them.
keith_yam@hotmail.com
Yuenme
