03-31-2004 01:54 PM - edited 03-13-2019 04:29 AM
Cisco AS5850 switch type 5ESS,
Voip->PSTN calls go out with the plans set as unknown, and I would like it to be national, I tried doing this in the translation rule but it seems to have no effect.
Any ideas are appreciated.
04-06-2004 12:38 PM
To convert the Numbering Type and Numbering Plan we have to use a voice translational rule.This feature is however available in 12.2(11)T.So please check which IOS version are you using.
please refer this link
04-06-2004 02:04 PM
Thanks but that wasn't changing it I found the command needed via searching through tac
it was
isdn map address .......... plan isdn type national
isdn map address 1.......... plan isdn type national
under the serial config for the span
thanks
