Issues with a Credit Card Machine using a VG202
Deancc3710_2
Has anyone run into any issues with using CC machines with using SCCP on a VG202?
Setup: 2 CC Machines--> VG202 --> connecting to Call Manager 8.6 using DHCP.  Both of my CC machines work fine doing a normal CC transaction, but at the end of the day the client runs a batch report on the cc machine but the cc machine will time out after 1 min.  The Batch report usually takes about 3 to 4 mins to complete.
paolo bevilacqua
Have you set network-clock correctly on teh PRI gateway ?
Can you elaborate on your response? I'm having a similar issue with a VG-224.
Thanks!
Lisa Coody
Thank you!
Adding "network-clock-select 1 T1 0/0/0" to the config resolved the issue. No more slips and credit card machine runs smoothly now.
I very much appreciate your assistance.
Thank you for the nice rating and good luck!
