Latency issues through IP Phones
cwestog
Seeing an extra 25ms of latency on PC's behind IP phones(7940's and 7910's). This is a small pilot network consisting of a colapsed core of dual 3750's (L3) and 4 3750's (L2) at the access layer and using a 3745 loaded with CME 3.3. Each switch has two data vlans/2voice vlans for redundancy. All tests/pings on the network to the phones result in 1ms delay, same result for PC's directly connected to the switch. Tests to a PC behind a phone result in roughly 23-28ms . PC to PC tests (behind phones) result in 60ms delay. Phones appear to work fine and no issues in calling each phone. Any ideas?
Steven Smith
Level 7
Level 7
CSCee86360 notes slow performance and is fixed in the 6.0(4.0) firmware. This may be what you are experiencing.
Upgraded the phones and no change in status, still have an extra 18-25 ms of delay pinging through a phone...thanks for the help though.
Problem appears to have cleared...went and blew away the configuration on the L2 switches and reloaded/reconfigured them(same configs) and the problem appears to be cleared. I am now seeing <1ms delay on all network testing through the IP phones. Not doing anything different...very odd. Thanks all.
