01-09-2006 02:22 PM - edited 03-13-2019 11:46 AM
When IP Communicators used by customers and the customer had for example 3 offices. I think there is a problem. The phone always used the same location. Is there some trick for this?
Maik
01-09-2006 04:43 PM
If I understand correctly you want an IP communicator to use different location based on where it is being used from?
The Location parameter is hard coded to the device, and does not update dynamically, you would have to change it everytime you move between locations. So, it behaves as expected.
Chris
01-10-2006 12:10 AM
That's right. But I hopes that there is some trick for this problem.
Maik
