Location with CTI Route Point
vinhnguyen
Does anybody knows whether Location setting will work with CTI Route Point?
Is there a documentation? I can't seem to get it to limit amount of calls to route point.
Chris Deren
I belive this is due to the fact that the call does not get connected to CTI RP for very long time, it is re-directed to a cti port whatever cti application is used, ie IPCC, etc. So you should be concerned about provisioning Location based CAC on CTI ports.
Chris
